Question Posts are not showing up
16 years 4 weeks ago #67472 by desktoplaptop
Whenever a user, or moderator posts on the forum the forum goes back to Recent Topics and the post does not show up. Everything was working fine but this just recently started. Configuration settings posted below.
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.10) | UddeIm: Disabled or not installed
16 years 4 weeks ago #67476 by xillibit
Replied by xillibit on topic Posts are not showing up
Are-you sure that this category isn't set on review by moderators ?
16 years 3 weeks ago #67972 by desktoplaptop
none of the categories are set for review there is a red x under Review in the category manager.
I had a couple posts working and then they stopped working all together. It's like it submits the posts but nothing shows
16 years 3 weeks ago #68053 by desktoplaptop
Is there a way to just reset all the settings back to default. Or should I just uninstall and reinstall Kunena when/if this happens. I really need to get the forums back up. If I need to reinstall the component is there a way to save personal settings like posts and forum categories.
16 years 3 weeks ago #68079 by desktoplaptop
Problem solved. I clicked on the review by moderators for the forum category and then I noticed it was allowing me to post. I unchecked Review again and it still allowed me. So i just refreshed all of the forum categories. Everything is working now. hope that helps anyone who gets stuck!
