Question Multiple Lightbox Problem
16 years 1 month ago #66231 by Enes
In my Kunena 1.6 forum, if I add an image into a post and click on it, 3 different Lightbox opening. So after I see it I have to close 3 different lightbox.
How to make image appears in one lightbox?
16 years 1 month ago #66239 by fxstein
Replied by fxstein on topic Multiple Lightbox Problem
For Kunena 1.6.1 we added a config parameter whether or not to use the Kunena supplied lighbox. If you have two more, that means you have at least one too many in your system setup (profile, plugins or modules).
With the upcoming 1.6.1 you will be able to disable the Kunena lightbox if you want to use a different one through your site template.
16 years 1 month ago #66260 by Enes
Replied by Enes on topic Multiple Lightbox Problem
OK Thanks, we are waiting for new release :)
15 years 11 months ago #71738 by brenden
Hi fxstein,
Was this feature you mentioned implemented in V1.6.1?
I ask as I have 1.6.1 and there is an option to enable Lightbox for Kunena, but when it is enabled I get two light boxes (as reported by the user).
When I turn it off I get none - not the Kunena light box nor the third party one I use.
The URL is www.bonsaisouth.com.au/cms3/index.php?op...5803&Itemid=89#15903
If you click on a image you see the issue.
Another issues is the Kunena light box is not displaying correctly. Only half the image is displayed. (half width).
Cheers,
Brenden
15 years 11 months ago #71768 by xillibit
You have a configuration setting for disable lightbox in k1.6.1 in the kunena configuration panel, in the tab frontend.
For the other issue, it will be fixed in k1.6.2.
15 years 11 months ago #71775 by brenden
Hi Xillibit,
Thanks for the reply. What I meant to say was I know I can disable lightbox using the configuration panel in the tab frontend. However, when I disable the Kunena lightbox it also disables my thirdparty lightbox module. So I have to use the currently buggy Kunena one or use none.
Great to hear the lightbox issues will be fixed in V1.6.2.
