Question Kunena forum menu arrangement Problem
16 years 1 month ago - 16 years 1 month ago #64476 by dingbusan
I've upgrade my Kunena forum from 1.5.12 to 1.6 now, everything is fine now but there's a strange arrangement problem, pls check as attached, pls kindly advise. thanks!
also see the URL: www.taiguoxin.com/forum/index.html
Last edit: 16 years 1 month ago by dingbusan.
16 years 1 month ago #64477 by sozzled
G'day, dingbusan. You might find this topic useful to you: Menu tabs display vertically (1.6.0 final)
Could you please tell us, what is the Joomla site template that you are using? Is it a Joomlart template by any chance? Thanks :)
The following user(s) said Thank You: dingbusan
16 years 1 month ago - 16 years 1 month ago #64479 by dingbusan
I'm using joomlart : JA_Sulfur template, pls kindly note
To modify my problem, should I do as following?
added a Module Class Suffix of "_kun" to the Kunena Menu, then added the same suffix in the kunena.forum.css
#Kunena #ktab div.moduletable_kun ul.menu li {
display: inline;
float: left;
margin: 2px 2px 0 0!important;
padding: 0;
border: 0;
As I tested, it's working now, the solution above is great, thanks!
