Question Edit text for POLLS
The correct file location is ../administrator/components/com_kunena/language/en-GB/en-GB.com_kunena.ini
The case of files names is important when you are using Apache web servers, too.
sozzled wrote: That file location is incorrect. Common mistake, as I wrote.
okay, i grabbed the file and am searching for the word PARTICIPATE like stated in my post #1..... it's not in the file. the phrase i'm looking to edit is NO WHERE in the file that i grabbed from the location you stated.
- There is ../administrator/components/com_kunena/language/en-GB/en-GB.com_kunena.ini which is for the backend
- There is ../language/en-GB/en-GB.com_kunena.ini (which is something new) for the front end - xillibit was right, earlier, except that he was referring to a French-language file. You made a mistake in spelling the file with the correct letter case (I think); and
- There is ../components/com_kunena/template/default/language/en-GB/en-GB.com_kunena.ini (which is something else) for template settings
You need to change the second of the three files I listed above. I'm sorry about the confusion. The Wiki article needs to be updated/improved and, maybe, someone can do that for us. You, perhaps?
sozzled wrote: Excuse me for completely messing up this topic. When we read the Wiki article, What is the language file in Kunena 1.6 we see (as I saw for the first time today) there are three language files:
No wonder you were confused. I was confused, too. It's because I rarely change anything in Kunena - everything works fine for me, straight out of the box - I've never bother to look at this . I might wear this fancy moderator's hat but I'm just a user, too, you know
That's why it took me a while to figure out which file needed to be changed in this case.
BINGO!!!! #2 was it.... thank you so much.
kunena works great for me too... it's just that the original wording didn't make sense and i didn't want people to think bad of kunena because of improper wording.
Thanks. I'm glad that we were able to be some help to you.
