Question KLogin for Kunena 1.6 (avatar integration problem)
16 years 2 months ago - 16 years 2 months ago #62501 by kubson.cz
hello!
this module has been made for kunena 1.5. now, in kunena 1.6 it's working fine, but the only problem is about avatars. KLogin can't integrate avatars with kunena. what i need to change to fix it?
below i paste a piece of code from 'vertical.php'
// ############# KUNENA AVATAR ################ $my = &JFactory::getUser(); $db = &JFactory::getDBO(); $db->setQuery("SELECT su.avatar FROM #__fb_users as su" . "\nLEFT JOIN #__users as u on u.id=su.userid WHERE su.userid={$my->id} LIMIT 1"); $_user = $db->loadObject(); $fbavatar = NULL; if ($_user != NULL) { $fbavatar = $_user->avatar; } if ($fbavatar != "") { if(!file_exists($avatar_upload_path .DS. 'avatars/l_' . $fbavatar)) { $avatar = '<a href="'. $avatar_link .'"><img class="login" src="'.$avatar_upload_path . $fbavatar . '" alt=" " title="'.JText::_('Newavatar').'" width="'.$params->get('avatar_w').'" /></a>'; } else { $avatar = '<a href="'. $avatar_link .'"><img class="login" src="'. $avatar_upload_path . 'l_' . $fbavatar . '" alt=" " title="'.JText::_('Newavatar').'" width="'.$params->get('avatar_w').'" /></a>'; } } else { $avatar = '<a href="'. $avatar_link .'"><img class="login" src="'. $avatar_upload_path .'nophoto.jpg" alt=" " title="'.JText::_('Newavatar').'" width="'.$params->get('avatar_w').'" /></a>'; } // ############# / END KUNENA ################### echo $avatar; break; case 1:
Last edit: 16 years 2 months ago by kubson.cz.
16 years 2 months ago #62532 by fxstein
Please uninstall this older plugin. The same plugin (from the same author) has not been made part of Kunena itself. Go to our download section and click on the link to download extensions. You will see a Kunena Login module 1.6 RC2 that handles all the proper integrations with Kunena 1.6
Hope this helps!
The following user(s) said Thank You: kubson.cz
16 years 2 months ago #62564 by kubson.cz
