Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question [Merged topic] The great CAPTCHA problem discussion
14 years 8 months ago #99294 by Inlinerbutch
Helli Xillibit,
in the "old" installation I am using the sytem captcha you have linked in your post and I would like to use this again but the plugin parameters are not set able ( see attachments ). Maybe it is possible to set the parameters in the database. This would help to fix this in the first step.
Jommla 1.5 with Kunena 1.6
Joomla 1.6 with Kunena 1.6
Regards
Inlinerbutch
The following user(s) said Thank You: dirkovision
The topic has been locked.
14 years 8 months ago #99299 by xillibit
This plugin needs some changes on this xml manifest file to work under Joomla! 1.6
14 years 8 months ago #100592 by Foyle
Inlinerbutch wrote: Hello all,
I finished the migration from J1.5 -> J1.6 and everything is running fine. Now I want to enable a captcha function in K1.6 to make it possible that also unregisterd users are able to write in some parts of the forum but it seems that there is no working captcha. For J1.6 I am using EasyCalcCheck PLUS - ECC+. Does someone know a soloution or will one of the next versions of Kunena have a captcha function?
Regards
Inlinerbutch
Hello, Inlinerbutch. I have adapted ECC+ for my needs so it works with j1.6 and Kunena 1.6.4. Though i was lazy to realise some features like text field restoring on wrong capture input and some other stuff. But the captcha itself works and if u need i can send it to u.
14 years 7 months ago - 14 years 7 months ago #103243 by glassparman
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : rt_modulus_j16 | author: RocketTheme, LLC | version: 1.6.0 | creationdate: June 1, 2011
Third-party components: CommunityBuilder 1.7
Is there a working CAPTCHA for Kunena 1.6.5 and Joomla 1.7? Everything I try does not show up in Kunena even though I have the feature enabled in Kunena Security.
Last edit: 14 years 7 months ago by glassparman.
14 years 7 months ago #103580 by Garry1953
I must admit it is a pain not being able to open the Guest Posting in Kunena 1.7 because of all the spam you get.
So I popped a suggestion in the feedback and sugestions section.
You can Vote for it here.
14 years 7 months ago - 14 years 7 months ago #103846 by maxus
is the empty form issue fixed in Kunena 1.6.5?
Last edit: 14 years 7 months ago by maxus.
Time to create page: 0.446 seconds
