Sticky [Merged topic] What do I need to do to get private messages working on my forum?
15 years 10 months ago #75241 by xillibit
Replied by xillibit on topic Private Message - PM
Kunena doesn't have a private message integrated on it but drive you to use a third party component to do that.
UddeIm is good choice, if you are using Jomsocial this integrate a pm system in it so you can use it.
15 years 10 months ago - 15 years 10 months ago #75252 by Elnablo
Replied by Elnablo on topic Re: Private Message - PM
VERY COOL!!!!! :woohoo:
Already up and running!!!!
You just have to watch out when creating lists! The default delimiter did not work for me, but after I changed it to ';' it was fine.
"UddeIm is good choice" is a perfect understatement. Works perfect with KUNENA, integrates very nicely into my site and is very logical as far as the setup goes.
Last edit: 15 years 10 months ago by Elnablo.
15 years 8 months ago #84574 by LukeDouglas
Replied by LukeDouglas on topic Private Messages
I cannot find how one member can send another member a private message. Is there functionality like this or an extension that provides this functionality? I couldn't fine either.
If there isn't a functionality like this, it 'really' needs to be implemented.
15 years 8 months ago #84581 by snilloconator
Replied by snilloconator on topic Re: Private Messages
Best choice would probably be uddeIM!
extensions.joomla.org/extensions/communication/pms/3206
This is an option in Kunena's backend under integration in the config section.
15 years 4 months ago #95237 by frenostanco
Replied by frenostanco on topic Private messages
As I understand, sending PM (private messages) between forum users is not a standard feature of kunena 1.6.3, I'm right?
(Yes, I will upgrade to 1.6.4 asap)
Hello to everybody!
15 years 4 months ago - 15 years 4 months ago #95238 by anonymous01
Replied by anonymous01 on topic Re: Private messages
Address, for example, to uddeim .
Last edit: 15 years 4 months ago by anonymous01.
