- Thank you received: 7
Question Change Default Sort?
Just to be very clear, you are describing the order of topics as they appear on each category page (see example in the following image):
The sort order is hard-coded. The order is based on the most recently posted message in each topic; you can think of this as the thread's "update time". Topics/threads are sorted in descending chronological sequence based on the thread's "update time". How else would you want these to be sorted? The most recently updated discussion is at the top and the list shows progressively older discussions as you move down the list.
sozzled wrote: I think the short answer, based on your explanation of the issue, is no.
Don't worry I found the php file I was looking for and changed the sql.
