Solved Why is there a conflict between my Kunena Login and my site login?
when i try and login or logout using the login module (menu bar) for my site I get this message
SSL connection error Unable to make a secure connection to the server. This may be a problem with the server, or it may be requiring a client authentication certificate that you don't have. Error 107 (net::ERR_SSL_PROTOCOL_ERROR): SSL protocol error.
however I can login using the same LI and PW in the login that sits within Kunena... I can logout successfully as well in kunena
my site settings are
Site > Global Configuration > Server > Server settings > Force SSL > None
Extensions > Module Manager > [LoginModule] > Basic Options > Encrypt Login Form > No
right now I am working off MAMP (localhost) and I think everything else is functioning the way I want but this one is obviously a concern as I would like others to be able to log into my site
I have checked both the kunena user manager and site user manager and all users are present and identical in setup
when I login using the kunena login it then shows me as logged in in the menu login as well
suggestions?
its published in the menu position of the template... I tried selecting No for Encrypt Login Form as well but that didn't seem to change anything
the login form on my menu does not work... but if I go to menu manager and publish a Login menu item it appears on my menu (as well as the login form)... and this one works... and my name appears on the login form as being logged in... I can then log out from the login page that comes up but not from the login form... the log in form is a simple drop down menu module whereas the new Login menu item goes to a separate page to login... it works but is not as efficient...
It would help us a lot if you posted your K 1.7 configuration report. We cannot comment on modules that may be included with third-party developed modules, such as the things that may be included with YooTheme templates. Those are matters that you may need to discuss with the developers of YooTheme templates. Ask them, "Does your login form work with Kunena?" and see what is their response.pondball wrote: The login form on my menu does not work ...
Without seeing your configuration report I don't know how to properly classify where this topic properly belongs, sorry.
