Solved Why is there a conflict between my Kunena Login and my site login?
14 years 5 months ago #123778 by pondball
I am using the yoo_theme Cloud template
when i try and login or logout using the login module (menu bar) for my site I get this message
SSL connection error Unable to make a secure connection to the server. This may be a problem with the server, or it may be requiring a client authentication certificate that you don't have. Error 107 (net::ERR_SSL_PROTOCOL_ERROR): SSL protocol error.
however I can login using the same LI and PW in the login that sits within Kunena... I can logout successfully as well in kunena
my site settings are
Site > Global Configuration > Server > Server settings > Force SSL > None
Extensions > Module Manager > [LoginModule] > Basic Options > Encrypt Login Form > No
right now I am working off MAMP (localhost) and I think everything else is functioning the way I want but this one is obviously a concern as I would like others to be able to log into my site
I have checked both the kunena user manager and site user manager and all users are present and identical in setup
when I login using the kunena login it then shows me as logged in in the menu login as well
suggestions?
14 years 5 months ago #123786 by Matias
Which login module are you using?
14 years 5 months ago #123789 by pondball
I believe its the Login Form that came with the yootheme Cloud... I can't see where there is a way to check the version number though...
its published in the menu position of the template... I tried selecting No for Encrypt Login Form as well but that didn't seem to change anything
14 years 5 months ago #123791 by pondball
ok... now you've got me hunting even deeper...
the login form on my menu does not work... but if I go to menu manager and publish a Login menu item it appears on my menu (as well as the login form)... and this one works... and my name appears on the login form as being logged in... I can then log out from the login page that comes up but not from the login form... the log in form is a simple drop down menu module whereas the new Login menu item goes to a separate page to login... it works but is not as efficient...
14 years 5 months ago - 14 years 5 months ago #123803 by sozzled
pondball wrote: The login form on my menu does not work ...
It would help us a lot if you posted your K 1.7 configuration report. We cannot comment on modules that may be included with third-party developed modules, such as the things that may be included with YooTheme templates. Those are matters that you may need to discuss with the developers of YooTheme templates. Ask them, "Does your login form work with Kunena?" and see what is their response.
Without seeing your configuration report I don't know how to properly classify where this topic properly belongs, sorry.
Last edit: 14 years 5 months ago by sozzled.
14 years 5 months ago #123817 by pondball
I've got to apologize for this next question... relatively new to joomla... where do I find the configuration report?
