Solved K1.7.2 userlist - do not show blocked users
14 years 6 months ago - 14 years 6 months ago #123554 by xdave78
Hi there,
I´ve got a little prob with that Kunena userlist. I want it NOT to show the blocked users anymore. I looked up the userlist.php in the func folder. But I´m not that good in php to fix this. Perhaps someone of you is able to help me with that. I´m pretty sure its just a lottle CODE Snipped for one of you out there.
I tried for testing to change this
// Total $this->db->setQuery ( "SELECT COUNT(*) FROM #__users WHERE {$where}" ); $this->total = $this->db->loadResult (); KunenaError::checkDatabaseError();
to that
// Total $this->db->setQuery ( "SELECT COUNT(*) FROM #__users WHERE WHERE 'block=0'" ); $this->total = $this->db->loadResult (); KunenaError::checkDatabaseError();
But with no Effect on the List itself.
Please help me.
Regards Dave
Last edit: 14 years 6 months ago by sozzled. Reason: Change topic icon
14 years 6 months ago #123570 by LittleJohn
Replied by LittleJohn on topic Userlist Problem K1.7.2
I believe what you are looking for, is the configuration option for this.
Go to backend.
Go to Kunena 'Forum Configuration' - Tab 'Frontend'
Look in the bottom for the setting 'User Count Contains'
Choose 'Only Active Users'
Does this help?
The following user(s) said Thank You: xdave78
14 years 6 months ago #123593 by xdave78
Replied by xdave78 on topic Userlist Problem K1.7.2
Oh, thanks a lot. In the german translation the title of this Option is not so clear as in the english Version. Typical case of "Lost in Translation" i guess ;)
OK it works now. Thanks a lot.
Regards
