Solved Add Rights Ok, Remove Rights Doesn't Work
14 years 7 months ago - 14 years 7 months ago #122920 by vova
Okay so I have a weird problem here I noticed while walking someone through his new website. I have three categories on my site for three levels of members (let's say 1, 2 and 3).
If I add level 2 to a user, he can see the level 2 categories no problem. But if I remove level 2 it does not remove his access to level 2 categories. The only way around this is to go back to those categories, select level 2 again, and save. This seems to refresh it and kick it into gear.
I have tested this numerous times and am nearly 100% confident this is what is causing the problem.
Config report to follow (btw using groups, and if I use joomla or CB in the settings).
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 50M | Max file upload: 15M
Joomla default template details : officeprime-tg | author: TG | version: 1.7.0 | creationdate: 19-10-2011
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.6
Last edit: 14 years 7 months ago by sozzled. Reason: Change topic icon
14 years 7 months ago #122922 by Matias
Kunena 1.7 ACL gets cached into the database and you need to run Synchronize users to get the effect right away. K2.0 changes this and keeps ACL inside session, which means that logout will do it in the new version.
The following user(s) said Thank You: vova
14 years 7 months ago #122923 by vova
Awesome thank you. The extra step is not a problem, my fear is that I want to finish this site and then have minimal participation. Each exception and special scenario is one more excuse for me to get pulled back in. But if it is as simple as "after chaging user permissions, synch users in forum" then that is a piece of cake :lol:.
14 years 7 months ago #123163 by michalis
forgive me for my ignorance, but what software are using to give diferent levels of access? I am looking for some but no luck
