- Thank you received: 1
Solved Categories showing as zero
- mikefriendly
- Junior Member
'Kunena Internal Error: Please enable Kunena Debug Mode and report problem in the www.kunena.org forum.'
The debug mode did not show any problems apart from one with an s4j module
I repaired the table 'jos_kunena_categories' and it is up and running again but...
The category index is only showing one topic, one which I posted since the repair.
All the topics and replies seem to be there and visible in the front end but not on the index.
Any ideas please?
www.buzz50.com/index.php/forum/index
- mikefriendly
- Junior Member
Only a few categories have dates/times in them.
In passing, did you resolve the problems that you reported to us earlier: You have reported problems in the past; we advised you several times to eliminate your dependence on J! 1.5 "legacy mode"; I want to be sure that we are not enabling a problem, like the ones you've reported, to repeat themselves again in the future. Can you please revisit each of the above topics that I have mentioned above and post your understanding of the current situation in each of those cases. Thanks.
- mikefriendly
- Junior Member
I am now on Joomla 2.5 and Kunena 1.7 so no legacy mode.
Strangely, the remaining problem of no tropics in the category index has cured itself!
