Bug Users cannot see all forum categories while they are granted to
14 years 7 months ago #122683 by sebnunes
Hi all,
I'm having troubles for a few weeks now and I cannot find any fix for this.
I'm running Joomla 1.5.25 & Kunena 1.7.2.
We have defined permisions for registered users to see only the Presentation category and as soon as their account is validated by the Administrator we change the account to Author and they should have access to many other categories.
It works like this for more than two years now, but since a couple of weeks all new users are having the same problem, despite the user account is added to the Author group, they can't see any other categories than the presentation one.
If I delete the account and recreate it myself, and add the account to the Author role, it works.
This is a nightmare as I'm having more and more users siging up for an account on the web site.
Any idea to fix this ?
Below the configuration report.
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 384M | Max file upload: 100M
Joomla default template details : dsb2011 | author: Sébastien Nunes | version: 1.0.0 | creationdate: 31/12/2010
Kunena default template details : Aphotic II | author: snilloconator | version: 1.6.2 | creationdate: 2010-12-30
Third-party components: UddeIm 2.1
14 years 7 months ago - 14 years 7 months ago #122711 by sozzled
Please read Legacy mode in the Wiki. We do not provide support for J! 1.5 sites that have the System - Legacy plugin enabled.
You are using a third-party template that was designed for an older version of Kunena that is no longer supported. Please contact the author of that template for information about an update or, if you do not want to do that, please use the standard Blue Eagle template.
You have a highly customised menu structure. Please ensure that your menu conforms to the recommendations made in Customised menus .
sebnunes wrote: ... despite the user account is added to the Author group, they can't see any other categories ...
How is the user account "added" to the Author group? Is this done at registration time or is this done later, by you? I think this is really the key to resolving the problem. I also think we can solve this problem in less than one minute, too! Can you please tell us how users are "added" to the Author group on your site?
Last edit: 14 years 7 months ago by sozzled.
14 years 7 months ago #122734 by sebnunes
Thanks for your reply.
We actually have a custom module where the admin can select users and click a "validate" button which adds the user to the Author group.
When I check in Joomla Admin module I can see that the users are effectively in the Author group.
Is there something wrong about doing it this way ?
14 years 7 months ago #122736 by sozzled
No problem really, in doing things this way, but you need to keep in mind that Kunena category access is only checked once, per session. Therefore, if a user is till logged-in when their access is changed, they won't see any different categories until they're logged out again or unless you purge the session cache. You purge the session cache by invoking the Synchronize Users function in the backend.
If your custom module could automatically invoke this Synchronize Users function then you would not have any problems. Alternatively, invite your users to logout then login again and they should see the categories they're entitled to. Or, manually, run Synchronize Users yourself.
Problems like these are fairly uncommon in J! 2.5.
14 years 7 months ago #122738 by sebnunes
Yeah but I already asks the users to logoff/logon again but they still can't see all categories.
I don't understand why. The only workaround I've found, is to manually delete the account and recreate it and add it to the Author group.
And it works like this for more than two years and suddenly it stopped working.
I know I should move to J2.5 and we are working on this, but in the meantime I still have new users coming and complaining about this... :(
Thanks for your help.
14 years 7 months ago - 14 years 7 months ago #122752 by Matias
Are the topics visible after they have slept overnight? How long is your Kunena session time? It should be less than 8 hours.
PS. this issue has been fixed in K2.0.
Last edit: 14 years 7 months ago by Matias.
