Question Attachments with spaces in filenames overwrite previous uploaded attachments
14 years 8 months ago - 14 years 8 months ago #121102 by wincash
Hi
I m using Kunena 1.7.2 on Joomla 2.5.1 and i have a problem with attachment file in kynena
The problem appears when a user upload a file whith a space in the name (ie "sans titre.png") the file is automaticly renammed in "sanstitre.png"... No problem for the first upload, but when someone upload an other file nammed "sans titre.png" the file was rename in sanstitre.png and replace the old one. Seems there is no check if it exist or not...
But if you don't use space in the name file, all was ok and the file was carrectly renammed...
If was a "big" problem because by default files was nammed "sans titre.*" in some (french) application
Sure i ash to user to don't use name whith space but... :)
let me show you :)
normally it was a white one in a red square.
Last edit: 14 years 8 months ago by wincash.
14 years 8 months ago - 14 years 8 months ago #121103 by wincash
and if i upload another one different (blue)
sans titre.jpg was rename in sanstitre.jpg too (without checking if an other one exist) and the attachement in the previously post change too
(hope you have the problem too :)
update
Yeah( sorry :) ) you have the problem too
if i send you the same file without space (i change name too ) you have :
hope you can fixed it
best regards
14 years 8 months ago #121111 by sozzled
wincash wrote: Hope you can fixed it
Fix what, exactly? Everything is working fine. Your examples prove that everything is working fine. I'm sorry. I don't understand the problem.
14 years 8 months ago - 14 years 8 months ago #121257 by wincash
I will try, with my poor english to explain :)
If you send a attachment call "sans titre.jpg", the script will rename in "sanstitre.jpg"
no problem with that
But if, in an other post, you link a new attachement with the same name "sans titre.jpg" (with the space)
The second attachement will already renamed in "sanstitre.jpg".. and will replace the 1st attachement.
and you have finally the 1er post, with the attachement of the second one
The secong post have a correct attachement until somebody use the same name (with space) for his attachement and, with the third post, the attachement of post 1 and post 2 will replace by the attachement of the post 3 etc etc etc...
the case is only when you use a file name attachement with a space in the name..
please try to send different file called "sans titre.jpg" in several post an d you will show it...;)
The solution was, to check if a file exist whith the same name but without space to renamed it correctly or to "lock" upload attachement with a space
Now you have :
1 post : sans titre.jpg -> sanstitre.jpg
2 post : sans titre.jpg -> sanstitre.jpg
and you normally will have
2 post : sans titre.jpg -> sanstitre-03-27-12.jpg (or something like that (like other file in fact)
rgds
14 years 8 months ago #121269 by sozzled
I understand the issue. I will report this to the development team to make sure that it's fixed in K 2.0.
In the meantime, don't use image filenames that contain spaces. Simple. Problem solved. ;)
14 years 7 months ago - 14 years 7 months ago #121401 by cleweb
"n the meantime, don't use image filenames that contain spaces. Simple. Problem solve"
Be sure that's i asked to my user when i saw the problem
thanks
Last edit: 14 years 7 months ago by cleweb.
