Question [Resolved] Categories locked
14 years 8 months ago #120732 by vrouwenvoetbal
Good morning
Recently my site www.vrouwenvoetbalnederland.nl has been changed from joomla 1.0 (with Fireboard0 to Joomla 1.5 with Kuena.
However, I have problems with posting, all my categories appeared to be locked, and in the backend they are all published for the public.
This morning I have uploaded 1.7.2 Kuena and disable the Legacy Mode
However, this didn't work for me.
Also I have some errors, like JFolder::create: Could not create directory
Can anybode help me what's wrong with my Forum?
As a Moderator I can post and delete messages.
But I tried als as new visitor, nothing :huh:
Thanks for any help.
Regards
Saskia
14 years 8 months ago #120752 by sozzled
Replied by sozzled on topic Re: Categories locked
G'day, Saskia , and welcome to Kunena.
I have seen this happen before, in one or two cases, when a category becomes locked. This sometimes occurs because the section (the container for a number of categories) becomes locked and there's no direct way to unlock a section. For an understanding of the terms "section" and "category", see Sections, Categories, sub-Categories (Part 1) .
It's easy enough to unlock sections. What you do is convert the section into a category of another section, and then you can unlock it using the Kunena Category Manager. After you do that, you convert it back into a section and then you should be OK. It's not easy for me to explain how to do this in words, but it's not really too hard to do. You could also unlock any locked sections or categories if you were comfortable with modifying the SQL tables but we do not recommend doing things that way on this forum (see How To Destroy your forum data... )
The other matter you raised - JFolder::create: Could not create directory - is quite important. Usually this problem occurs because of a folder/file permissions problem on your website. Please read Securing Kunena for tips on what you should do. I hope some of this helps. :)
14 years 8 months ago #120767 by vrouwenvoetbal
Thanks for your quick reply back.
Indeed I had the section and category locked myself. I was confused by the green box for yes.
Oh well problem solved.
The other problem, I have changed all the folder/directories with correct CHMOD, however, still the same.
Saskia
14 years 8 months ago #120771 by sozzled
I'm pleased to hear that we resolved the question you asked about locked categories.
Your second question, however, is off-topic to this subject and deserves separate treatment. You should search the forum for "JFolder::create: Could not create directory" to see other topics where this question has been asked and answered.
We do not want to confuse other people reading this topic (who are hoping it will answer your question about locked categories") if we continue to discuss your other problem here. OK?
