Question no subcategories in recent topics
14 years 9 months ago - 14 years 9 months ago #119395 by cbrace
Hi Sozzled, hi fellow k-boarders,
Last weekend I created for the first time around half-dozen sub-categories on my Kunena forum. These are third-level sub-forums, if you will. Their tiny icons appear in a little horizontal list under the parent category. So far, so good.
However, for some reason, new posts entered in these sub-categories are not showing up in Recent topics. I have reviewed the settings in the Kunena Category manager and nothing caught my eye. Am I missing something here?
Kunena 1.7.2
Last edit: 14 years 9 months ago by cbrace. Reason: Kunena 1.7.2
14 years 9 months ago #119399 by Jiminimonka
Please post your configuration report, maybe it will help.
Thanks.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago - 14 years 9 months ago #119400 by cbrace
[strike]OK, here it is:[/strike]
Last edit: 14 years 9 months ago by cbrace. Reason: solved
14 years 9 months ago #119401 by cbrace
Ah found it: Category List in Recent Topic wasn't set to all.
Solved.
14 years 9 months ago #119402 by Jiminimonka
Your configuration report does not show what version of UddeIM you are using, that is on 2.6 now I believe. Community Builder is now on version 1.8 so that should also be upgraded.
Your Kunena template is very much out of date, perhaps you should contact the author and get an upgrade that works with K1.7.2?
