Question Where is it?
14 years 9 months ago #117439 by fbastage
Where is it? was created by fbastage
This should be a stupid question, and yet I can't find any info at all.
I'm new to Joomla and Kunena. Just installed them right now (2.5 and 1.7.2, respectively). Install is successful. So..
Where is it? How does a user access the kunena forum on the front end? What's its url?
14 years 9 months ago #117444 by fbastage
Replied by fbastage on topic Re: Where is it?
believe I have found it
{root}/index.php/forum/
14 years 9 months ago #117447 by Matias
Replied by Matias on topic Re: Where is it?
You need to read the manual. :)
Just go to your main menu (with yellow star) and publish Kunena menu item.
The following user(s) said Thank You: yuzef, fbastage
14 years 9 months ago #117453 by fbastage
thanks, I found the menu controls you mentioned. I'm definitely reading more of the 'manual', but I appreciate the quick reply and help as well.
14 years 9 months ago #117491 by yuzef
Replied by yuzef on topic Re: Where is it?
Matias wrote: You need to read the manual. :)
I respect Kunena way to make make is Unpublished by default, but i think its will be more great to make it Published by default as Jomsocial made it.
This will be useful for newbies and the kunena user starter (as this thread first poster asked)
Love Simplicty
read...... and learn........
My Joomla Test Site
14 years 9 months ago #117496 by sozzled
Replied by sozzled on topic Re: Where is it?
yuzef wrote: I respect Kunena way to make make is Unpublished by default, but i think its will be more great to make it Published by default as Jomsocial made it.
If Joomla was designed the same way in J! 1.5, J! 1.6, J! 1.7, J! 2.5 then there would be no need for special case handling. K 1.7.2 is designed to install (from a single kit) into any of these versions ... and do it all within a file less than 2 Mb. Some things just can't be done that easily. Sorry.
