Question Users able to post to locked Categories
14 years 9 months ago - 14 years 9 months ago #117338 by adricist
I am having a strange issue with users being able to post to a locked Category. My Forums are structured in 3 levels with Sections(1), Category(2) and Subcategory(3). Sections are fine as you cannot post to them directly. I have locked all my Categories, as I need them only as SubSections and I am allowing Registered users only to post in the Subcategories or level 3. The problem I am having is that although the Categories at Level 2 show the padlock icon if a user clicks them they can still post to them! :unsure: If however I navigate from the top Menu Tabs to that Level 2 Category, then I am only able to post to the Subcategory at Level 3, which is perfect.
Can someone please explain to me why the users are able to post to that Level 2 if they navigate there from the main Index page? I have tried also setting the access of those level 2 Categories to Nobody but it makes no difference! Even though I have them Locked and with Nobody, users can still post!
Any help with be greatly appreciated.
Thanks,
Adri
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Missing | PHP environment: Max execution time: 800 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : ja_regulus_ex | author: JoomlArt.com | version: Extra | creationdate: 19 Jul 06
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: CommunityBuilder 1.7.1
Last edit: 14 years 9 months ago by adricist.
14 years 9 months ago #117343 by sozzled
Please read Legacy mode.
Upgrade to K 1.7.2. Please upgrade to J! 1.5.25.
You have a really complicated Joomla menu structure. Is there some way you can simplify it?
14 years 9 months ago #117348 by adricist
Thank you for your prompt reply.
I will upgrade both Joomla and Kunena and report back!
Adri
14 years 9 months ago #117352 by sozzled
Don't forget: disable the System - Legacy plugin. It's important. :)
14 years 9 months ago #117379 by adricist
Ok,
I have setup a cloned site and I have done all the updates but unfortunately no difference! :(
What else could it be?
Adri
Joomla default template details : ja_hedera | author: JoomlArt.com | version: 1.1.0 | creationdate: 10/13/07
14 years 9 months ago #117381 by sozzled
I cannot see any topics/categories on your website. Have you a test account we could use to login please? Test account should be non-privileged one. You can use the
Time to create page: 0.208 seconds
