Question [Resolved] Deleting posts permanently?
- missalexrowsell
From the forum, as a moderator/admin I am capable of "deleting" a topic, however it is still viewable by mods/admins. I found the purge trash option to remove it, but its there a way to set it up to automatically permanently delete when someone with sufficient privileges does so?
If you have deleted a post or a topic that you can still view it as a moderator/administrator, there will be a "Permanently delete" button. Use that.
You can permanently delete topics from the category Index view. Select the topic using the checkbox on the right and then choose "Permanently delete" from the selection at the bottom of the screen. This method bypasses the need to delete a topic first.
There is no way you can bypass the "delete-then-permanently-delete" procedure for a post.
- missalexrowsell
Is this maybe a setting we have somehow changed? If so, where is it found on the backend?
Thanks again for your quick response.
If you think you may have wrongly changed your configuration settings, you should post your configuration report.
- missalexrowsell
After I have deleted the thread (from within the thread), I get a permanently delete option on each post. Even when that is done for the OP, all the following posts need to be individually permanently deleted.
The full time administrator has said that if he has to purge, thats fine, he was just hoping for an automatic way to do it rather than going back side to do it.
