Bug [Problem assumed resolved - no response from user] SEF enable creates problem to Reply, Edit and Search
14 years 9 months ago - 14 years 9 months ago #116871 by hellilyntax
i just enabled SEF url in joomla,
everything is fine except these 3 thing,
1. Reply & Edit, i got this empty page
url for reply = demo.al-fikrah.net/forum/tips/3587-sef-e...roblem/post?do=reply
url for edit = demo.al-fikrah.net/forum/tips/3587-sef-e...problem/post?do=edit
2. Search
text in the input box = /forum/search?q=/carian/carian-forum
is there something wrong with my SEF config?
here is my report
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : ja_t3_blank | author: JoomlArt.com | version: 1.1.4 | creationdate: 11/08/10
Kunena default template details : Fast | author: gonzaunit | version: 1.6.x | creationdate: 2010-10-11
Third-party components: UddeIm
Modules: Kunena Latest 1.6.2 | Kunena Stats 1.6.2 | Kunena Login 1.6.2
Last edit: 14 years 9 months ago by hellilyntax.
14 years 9 months ago - 14 years 9 months ago #116918 by sozzled
I see that you have a complex menu structure. This makes it a little more difficult to solve on the forum.
Although these things are unrelated, I suggest that you upgrade Kunena Latest, Kunena Discuss and Kunena Login to version 1.7.1.
The Kunena template that you are using was designed for an older version of Kunena. It's possible that this template is the reason you are having problems, too. You might find it easier, while you're debugging your site, to use the Blue Eagle template; fix the menu problems and then see if the Fast template actually works. The Kunena project does not support the Fast template; priority support is given where people use the Blue Eagle template.
Setting up a Joomla menu is tricky. The guide to how to create a customised menu for Kunena is Customised menus . If you want something different (and you don't know how to setup Joomla menus) it may be worthwhile getting an experienced Joomla developer to help you. Otherwise, I would suggest that you try to keep your Joomla menu as simple as possible.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago #116944 by hellilyntax
thanks sozzled,
i will give a try on your suggestion...
14 years 6 months ago #123338 by sozzled
