Question No users can post
14 years 10 months ago #114225 by kevin29fan
No users can post was created by kevin29fan
When users try to post, the page loads normally at first, then suddenly the category list disappears and posting is impossible. I have tried changing the template back to the default one (I doubt this is the issue because super users can post just fine), I have checked the settings on the categories to make sure they were "allowed" for registered users and they are. I don't know what else to check. Right now, no one can post except super users.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : mixology | author: JoomlaXTC | version: 1.1.2 | creationdate: 2011-10-31
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: CommunityBuilder 1.7.1
Modules: Kunena Latest 1.7.1 | Kunena Search 1.7.1
14 years 10 months ago #114230 by xillibit
Replied by xillibit on topic Re: No users can post
Can-i see a screenshot of Kunena category manager, to see how you have configured it ?
14 years 10 months ago #114235 by kevin29fan
Replied by kevin29fan on topic Re: No users can post
The screenshot is attached. Hope it helps!
14 years 10 months ago - 14 years 10 months ago #114251 by sozzled
Replied by sozzled on topic Re: No users can post
When I visited your website, went to the Index page, saw the message "There are no categories in the section!". This means that you've set the security on your categories so that guests cannot see any of your Kunena categories. Perhaps the reason that your users cannot post is because they have not logged into your website? Have you eliminated this as a possibility (with a test "ordinary" user account)?
See Sections, Categories, sub-Categories (Part 1) . If a user can view a category, they can post to that category as long as the category is not locked. None of your categories are locked so that eliminates that possibility.
Last edit: 14 years 10 months ago by sozzled.
14 years 10 months ago #114256 by kevin29fan
ISSUE RESOLVED
I have changed the settings to public on all categories and I also clicked the "restore default settings" and the issue is solved. Thank you so much !!!
14 years 10 months ago #114276 by kevin29fan
Nope.. not resolved. It works in Firefox but not Internet Explorer. :( Do you have any suggestions on that? It was working fine until I upgraded to 1.7.1
Time to create page: 0.200 seconds
