Question Problems with Joomla 1.7.3 and Kunena
14 years 11 months ago - 14 years 11 months ago #113478
by studiozr
Problems with Joomla 1.7.3 and Kunena was created by studiozr
I use Joomla 1.7.3 with a new rockettheme template: Modulus.
The main menu of Kunena doesn't show up and profile can't be edited.
Rockettheme support says it is a "Kunena" problem.
Could you help me, please?
The site is:
www.mastering7.com
mastering7.com/index.php/2011-12-11-21-12-52
Thanks in advance!
The site is:
www.mastering7.com
Thanks in advance!
Last edit: 14 years 11 months ago by studiozr.
The topic has been locked.
14 years 11 months ago - 14 years 11 months ago #113487
Replied by sozzled on topic Re: Problems with Joomla 1.7.3 and Kunena
G'day, studiozr, and welcome to Kunena.
There are two different issues here.
Strictly-speaking, the missing Kunena menu is neither a Rockettheme problem nor a Kunena problem. It's a problem in the way that you setup your Joomla menus. This issue is addressed by the FAQ (see FAQs menu item at the top of this forum): How do I restore my Kunena menu?
The second problem that you're having - why you cannot edit your use profile - is caused by a Mootools/Javascript library conflict. In this regard your Rockettheme template could be a significant factor as to why you are having this problem. Most likely you need to change the Rockettheme advanced option "Build Title Spans = No" and that may help. We've dealt with this issue, too, on our FAQs page and in msg #1 of If you are having problems with Kunena, please read this first
Last edit: 14 years 11 months ago by sozzled.
14 years 11 months ago - 14 years 11 months ago #113557
by studiozr
Replied by studiozr on topic Re: Problems with Joomla 1.7.3 and Kunena
Thanks for the answer! The first issue solved like a breeze I didn't notice Kunena menu option.
14 years 11 months ago - 14 years 11 months ago #113564
by studiozr
The profile problem solved, too : I turned off "Built Titles Spams" in the joomla template's advanced menu.
Last edit: 14 years 11 months ago by sozzled. Reason: correct minor spelling mistake
14 years 11 months ago #113592
Next time, please use a single topic for each question and give the topic a more meaningful subject. I'm locking this topic in case someone else thinks that it's the only topic for discussing every kind of problem about K 1.7.1 and J! 1.7.3.
