Question synchronize users - not working
15 years 2 weeks ago #110760 by bellablue
Ok ..maybe I am doing something silly wrong here but I had a new member join yesterday and though on the frontend of Kunena it shows her in the bottom but in the backend - she is not there so I hit synchronize users and it claims it did? It also shows 84 users when on the front end it shows 94 - I need to make that new one a moderator but can't because she is not in the backend of Kunena ??? any suggestions
I am running joomla 1.6.4 and jomsocial 2.3 or 2.5 and I am running kunena 1.7 upgraded easily but confused why I am missing members in the backend?
Thank you kindly ....
:blush:
ANG
15 years 2 weeks ago - 15 years 2 weeks ago #110769 by sozzled
Thanks for your question, Ang.
One minor comment regarding J! 1.6.4. This was a fairly buggy version of Joomla and most people would not touch it with a 50-foot bargepole. Your best bet is to upgrade your website to J! 1.7.2 at the earliest opportunity.
That being said, when you go into the Synchronize Users panel, you will see 4 checkboxes. I suggest that you click all four of those checkboxes before you press the "Sync" button. I hope this helps. :)
Last edit: 15 years 2 weeks ago by sozzled.
The following user(s) said Thank You: bellablue
15 years 2 weeks ago #110771 by bellablue
that completely imported them checking all the boxes ... one last question a category I try to add a moderator and it is set to yes and saved and then I reopen it there is no add new to add anyone and I turned them on as moderators ... :unsure:
thanks for your help!
ANG
15 years 2 weeks ago #110773 by sozzled
Use the Kunena User Manager to assign moderators. This is covered in the topic How to assign a moderator in K 1.6? (the principle is the same for K 1.7 although some of the terms used in that topic may have changed). I hope that helps.
15 years 2 weeks ago #110776 by bellablue
totally worked fine .... last question since you have helped me so much .... is there a way to add a user to subscriptions without them adding themselves? I have a few I need to - currently I can only do it from the database ... thank you thank you thank you ...
15 years 2 weeks ago #110780 by sozzled
bellablue wrote: Is there a way to add a user to subscriptions without them adding themselves?
This question has been asked many times. The short answer is no. See [Merged Topic] Automatically subscribe all members to be notified of any new messages
Further questions, that do not relate to this topic (i.e. the Synchronize Users feature), should be asked as separate topics.
