Kunena 7.0.8 Released
Question K 1.7 - External images
14 years 10 months ago #107877 by Leon
Replied by Leon on topic Re: K 1.7 - External images
xillibit wrote: Disable all things related to yoo_effect
Done but same result.
14 years 10 months ago #107878 by xillibit
Disable all plugins to see if it's works better and then enable the plugins one by one to see which one is causing this defect
14 years 10 months ago #107879 by Leon
xillibit wrote: Disable all plugins to see if it's works better and then enable the plugins one by one to see which one is causing this defect
I have disabled all plugins (now are all enabled again) but I still can't see any external image :(
14 years 10 months ago #107993 by Leon
It doesn't make any sense to me, but I finally solved the problem changing a value in the kunena config.
In the Upload section, I had "Maximum Image Width" and "Maximum Image Height" set to 0. I changed that value and now I can see any external image in the forum.
Thanks!!
Time to create page: 0.315 seconds
