Question Fatal Error when replying/quoting to topic
15 years 2 months ago #107442 by feedmebits
mysql: 5.1.52
php: 5.3.2
Joomla: 1.7
I'm new to the forums and I'm running across something and I've seen a solution for it but the solution doesn't seem to work for me. I'm getting the following error when replying or quoting a topic: Fatal Error: Access to undeclared static property: KunenaAccessJoomla16::$viewLevels in components/com_kunena/libraries/integration/joomla16/access.php on line 127 and when I refresh the reply/quote does appear.
I found someone had the same problem here
I installed joomla without any problems and I installed the Kunena component without any problems. When I try to go to /administrator/components/com_kunena/libraries/integration/joomla16 via ssh the directory doesn't even exist. When I check under administrator compononents for com_kunena it doesn't exist there. I tried to check the path I get from the debug mode: com_kunena/libraries/integration/joomla16/ it doesn't exist either. I'm kind of confused why this directory doesn't exist in my kunena installation. I don't have any rights problems cuz all my directories are writable.
here's the report confuguration:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : joomlage0039-microlite | author: Joomlage | version: 1.6 | creationdate: 05-05-2011
15 years 2 months ago - 15 years 2 months ago #107452 by feedmebits
Strange the problem seems to have been solved after reinstalling kunena :) Thanks for this great component :D
Last edit: 15 years 2 months ago by feedmebits.
15 years 2 months ago #107483 by xillibit
The fix is given here : www.kunena.org/forum/168-k-16-and-k-17-s...in-kunena-170#105763
If you just reinstall Kunena, the issue will appear soon or later
15 years 2 months ago #107498 by feedmebits
xillibit wrote: Hello,
I did come across that solution but at the time I wasn't able to apply it because of a stupid mistake I made. I noticed my mistake after I reinstalled kunena. And I just applied the fix now. Thanks :)
