Question Jplayer and Kunena 1.7
15 years 2 months ago - 15 years 2 months ago #106771 by Jiminimonka
I just noticed this so I am assuming its since I upgraded to Kunena 1.7, but previously I could use the
Article cannot be shown
tag to point to a Joomla article, and if that article had a Jplayer tag {youtube}12311{/youtube} it would show up in the forums working as intended, but now it shows only the tag and the rest of the article as normal.
Does anyone know if this is something that got updated in K!1.7? JPlayer is at extensions.joomla.org/extensions/multime...yers-a-gallery/11572
Config detail below:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : rt_radiance | author: RocketTheme, LLC | version: 1.1 | creationdate: September 8, 2011
Third-party components: UddeIm 2.5
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.0
Modules: Kunena Latest 1.7.0 | Kunena Search 1.7.0
Please read the FAQ.
Only one question per topic.
Last edit: 15 years 2 months ago by Jiminimonka.
15 years 2 months ago #106804 by xillibit
Replied by xillibit on topic Re: Jplayer and Kunena 1.7
Check if Joomla plugin support is disabled in Kunena configuration panel
The following user(s) said Thank You: Jiminimonka
15 years 2 months ago #106811 by Jiminimonka
YAY!! Thanks Xillibit, don't know how that got turned off.
