Idea url undefined
15 years 3 months ago - 15 years 3 months ago #104743 by soundlover
url undefined was created by soundlover
It was good but today I don't know what happened and when I try to post something using bbcode, insert link, it comes as this:
url=undefined]undefined[/url
I removed the brackets at the start and end of code as here shows correctly.
Other previous links showing incorrectly too now. I changed some settings today. Maybe I changed something but have no idea what affects this particular problem. I restored default settings from forum configuration but did not solve the problem.
Last edit: 15 years 3 months ago by sozzled. Reason: Change topic icon
15 years 3 months ago #104755 by sozzled
Replied by sozzled on topic Re: url undefined
I've never heard of this happening before. Can we see your K 1.6 configuration report please? Have you made any changes to the Kunena PHP files? Maybe it's a templating issue?
15 years 3 months ago #104759 by soundlover
Replied by soundlover on topic Re: url undefined
Any idea what could affect bbcode this way?
15 years 3 months ago - 15 years 3 months ago #104760 by sozzled
The "example" template is not a template. The "example" template is a template design for your own template (if you want to build your own template) but it doesn't work. Let's stay with what we know: the Blue Eagle template, OK?
As you will see, if you read the posting guidelines that appear at the top of this page, it really would help if you could post your K 1.6 configuration report. How do you produce a configuration report? See the FAQs page (there's a menu tab above that takes you there): What information should I include when I ask for help (including how to post my configuration report)?
I've not heard of your case before. I don't know what has caused your problem. I asked you if you have changed any PHP files; have you?
We may need more information. Do you have a test account that we can use on your site? You can post details of the test account using the
15 years 3 months ago #104763 by soundlover
Did not change any php files recently. Few days ago it was good.
The only thing I did this last days was to migrate my site, same hosting provider but had to change plans as my old plan was closed.
I changed few settings today from admin panel, did not touch any files.
I will post a configuration report.
