Question Forum doesnt show up no matter what.
14 years 9 months ago #104045 by MYYZTIK
Here's my report
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : yoo_downtown | author: YOOtheme | version: 1.0.1 | creationdate: July 2011
Now Ive installed with sample data but when I create a menu item say entry page it doesnt show or if I change the menu item to catagories it doesnt show anything. here's the link spyderdesignz.com/retro
Any help would be great! Thanks all!
14 years 9 months ago #104093 by xillibit
Are-you sure that the forum isn't offline ? The installation has failed somewhere or it's correct ?
14 years 9 months ago #104103 by sozzled
G'day, MYYZTIK, and welcome to Kunena.
Your K 1.6 configuration report shows there is no Kunena menu. Please go to the FAQs tab on the menu near the top of this page. Please read Kunena menu issues
14 years 9 months ago #104352 by MYYZTIK
Correct me im wrong the but the Kunena menu is to create menu for the forums no?
Heres another report. My site not offline. Ive created a menu item that it Kunena Catagory page. Yes still nothing shows up..... install also went fine.
I also see moo tool is disbaled but no matter where I go I cant find where to enable it..........
you can also see a screen shot of the menu item here spyderdesignz.com/kunena.jpg
thanks everyone!
14 years 9 months ago #104354 by sozzled
Don't worry about Mootools.
I can't get to your forum no matter what I try to do. It's almost as if it's not installed on your site. It will not hurt to re-install Kunena again (see K 1.6 Upgrade Guide )
Your menu item "configuration" screenshot shows that what you're attempting to do is going about this all wrong. Don't change the menu item to "categories". Can you please read Please read Kunena menu issues and apply the trash-burn-build approach.
14 years 9 months ago - 14 years 9 months ago #104368 by MYYZTIK
Ive tried everything...I give up all Im trying to do is create a button for the front page of the website not the forums itself (aka menu item) to go to the forums..it really shouldnt be this hard....
Last edit: 14 years 9 months ago by MYYZTIK.
Time to create page: 0.312 seconds
