Question URL design
15 years 3 months ago #103933
by bdsigned
URL design was created by bdsigned
Hello all,
we have been searching for days now an were not able to find a solution.
Now you are our last hope
We would like to change the look of the url / link generated by Kunena.
This is how it looks like now:
.../forum/Wer-kennt-was-meint-Ihr-dazu/942850353-NSL-Consolidated-Limited
and we want to have it like this:
.../forum/Wer-kennt-was-meint-Ihr-dazu/NSL-Consolidated-Limited-942850353
We cant find where Kunena build this path and how to change it.
We hope you can help!
Any ideas or suggestions?
The topic has been locked.
15 years 3 months ago #103934
by mstephan
Replied by mstephan on topic Re: URL design
I don't think you'll find an easy way to do this without using one of these:
extensions.joomla.org/extensions/site-management/sef
15 years 3 months ago - 15 years 3 months ago #103948
by Matias
Replied by Matias on topic Re: URL design
The issue with turning topic id into postfix is that we use parameters which can look just like topics:
.../forum/Wer-kennt-was-meint-Ihr-dazu/sel-10
EDIT: We could use /forum/My-category/My-topic--10 or something else unique...
Last edit: 15 years 3 months ago by Matias.
15 years 3 months ago #103963
by bdsigned
Replied by bdsigned on topic Re: URL design
First off all we would like to thank you for your replies.
@Mstephan: I will take a look at it today.
@Matias:
The problem we are facing is, that we have a customer with an old forum (wbb3).
We managed to import all data, users and all 250.000 posts!!
But all links, generated by wbb3, look like this: Forum/Category/thread-130224.html
1. We want to grant that all links will still work when they follow a link from Google.
2. Internal links to jump from Topic to Topic must work
3. We want to avoid double posts in google. (Same topic but different link)
4. Some links are hardcoded in articles/content
This is why we have to find a solution. Best would be if we could find out how and where Kunena builds that links/url so we can change it. We just want that number at the end.
@Matias:
15 years 3 months ago #103987
by Matias
components/com_kunena/router.php
line 208-218 builds topic part of the URL
line 296-297 parses topic part of the URL
Build part is easy to change, parse needs some extra logic ($var-$value).
Also topic ids may change during the conversion as Kunena uses first post id as topic id (might change in 2.0).
The following user(s) said Thank You: bdsigned
15 years 3 months ago - 15 years 3 months ago #104304
by bdsigned
Thanks, that was what we are looking for.
It really helped.
*** Off-topic content removed by moderator - topic locked ***
It really helped.
Last edit: 15 years 3 months ago by sozzled.
