Question Move topics between categories
15 years 3 months ago - 15 years 3 months ago #103201 by zhumar
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : anittel | author: RocketTheme | version: 1.5.0 | creationdate: 08/07/09
I'm trying to use the quick moderation tools located at the bottom of the topic list to move a topic. I select the topic, select Move selected, but then the choose destination select box does not become active. If I just click Go, I get a Joomla notice that just says "55". My user is an administrator AND has moderator privileges on both forums I am trying to move between. Is this feature just broken or am I missing something?
Last edit: 15 years 3 months ago by zhumar.
15 years 3 months ago #103210 by xillibit
Can-you put screenshots like that i can see exactly the issue ?
15 years 3 months ago #103244 by zhumar
Attached is a screenshot that shows the "55" notice and that the Choose Destination select box does not become selectable.
15 years 3 months ago #103269 by sozzled
You have a Javascript library conflict - probably caused by Rockettheme template or a Rockettheme add-on - with Mootools. Please see msg #1 in If you are having problems with K 1.6, please read this first
The following user(s) said Thank You: zhumar
15 years 3 months ago #103311 by zhumar
I had to enable the mootools upgrade plugin. It seems to be working now. Thanks for the help!
