Question Forum Login redirecting to 404 and Profiles not working...
14 years 10 months ago #101660 by binnyhur
I have created a Gaming website and am obviously having troubles since I am here.
I cannot log in via the Login panel on the Forum page though it strangely works from any of my other module based login forms. Instead, I get redirected to a 404 page.
viralprogeny.com/forum/index.html
Also, there is an issue with the Profiles. The tabs show, but nothing else. I have tried clicking 'Edit' and nothing happens.
I am thinking there is a conflict between Kunena and my template from Rocket Theme or one of my many plugins. I have tried turning plugins off and troubleshooting this way, but have had no luck.
I aslo had tried installing an older version of JomSocial (1.2.192) and Kunena didn't work at all. Instead, I only got a 505 error whenever I opened the Forum page. I have since scrapped that idea and removed JomSocial in favor of Kunena.
I really would prefer the seamless integration of Kunena over Simple Machines or phpBB. Please help me resolve these issues. I like the way Kunena 'should' work. Hope we can make this happen over the next day or so. Maybe even get JomSocial to agree with Kunena.
I have created a 'Guest' login for anyone to test until this is resolved. If you feel confident and up for the challenge, and need to be given Admin status... Let me know.
Guest Access:
Username: guest123
Password: guest123
Here is a list of my current plugins just in case this is a common issue and just couldn't find the existing answer in the forum.
Authentication - Joomla
Authentication - LDAP
Authentication - OpenID
Authentication - GMail
Content - RokBox
Content - Kunena Discuss
Content - Page Navigation
Content - Rating
Content - Email Cloaking
Content - Code Hightlighter (GeSHi)
Content - Load Module
Content - Pagebreak
Content - JComments
Editor - No Editor
Editor - TinyMCE
Editor - XStandard Lite 2.0
Editor - RokPad
Editor - JoomlaFCK
Editor Button - Image
Editor Button - Pagebreak
Editor Button - Readmore
Button - RokCandy
Editor Button - JComments ON
Editor Button - JComments OFF
RokNavMenu - Boost
RokNavMenu - Extended Link
Search - Kunena
Search - Content
Search - Weblinks
Search - Contacts
Search - Categories
Search - Sections
Search - Newsfeeds
Search - JComments
System - JComments
System - RokGZipper
System - Kunena
System - Mootools Upgrade
System - Joo Recaptcha
System - RokGantry Cache
System - RokBox
System - Legacy
System - RokCandy
System - SEF
System - Debug
System - Cache
System - Log
System - Remember Me
System - Backlink
User - Joomla!
User - JComments
XML-RPC - Joomla
XML-RPC - Blogger API
The topic has been locked.
14 years 10 months ago #101661 by binnyhur
Also, here's my configuration report...
Joomla default template details : rt_dominion_j15 | author: RocketTheme | version: 1.5.6 | creationdate: February 12, 2010
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4 | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.4 | Kunena Login 1.6.4 | Kunena Search 1.6.4
14 years 10 months ago #101667 by sozzled
G'day, binnyhur, and welcome to Kunena.
Evidently you have a couple of problems.
Let's tackle the easier ones first: profiles not working (and a few other things that you did not mention). The RokCandy plugin is responsible for some of these problems; the Build Title Spans option in Rockettheme template is responsible for some others. These issues are addressed (in general terms) in msg #1 of If you are having problems with K 1.6, please read this first
The second matter, about the login redirection not working, is something else. There's one sure-fire way to identify if this is a problem with the Kunena Login module or something else: uninistall the Kunena Login module and see what happens next.
So, let's deal with the Javascript library conflict caused by various Rockettheme tools that you've installed and then we'll address the login matter after that.
14 years 10 months ago #101725 by binnyhur
I took a look and am trying to figure things out. I am not a pro coder. Know just basics and WYSIWYG.
I guess I'll have to pay someone or just give up. Not sure what to do.
Thanks for the link and info though. Just a bit complicated for me.
14 years 10 months ago #101728 by sozzled
I'll make it simple for you:
  • Disable/uninistall RokCandy plugin
  • Uninistall Kunena Login (I'm not saying there's something wrong; I'm just saying let's eliminate it as a possible problem)
  • Set Build Title Spans = Off in Rockethtteme template options
14 years 10 months ago - 14 years 10 months ago #101737 by binnyhur
Okay, did the RokCandy earlier. Just did Spans.
Login now done...
Do you need another report?
Last edit: 14 years 10 months ago by binnyhur.
Time to create page: 0.285 seconds
