Question Is there an alpha or beta available for Kuenna 1.6.5
14 years 9 months ago #101584
by deemo
Is there an alpha or beta available for Kuenna 1.6.5 was created by deemo
I updated my site to Joomla 1.7 without checking that Kuenna was compatible, my bad, i didn't check as the joomla developers were stating that it was only a minor upgrade and most components should work fine.
Unfortunately it doesn't tried to do a restore from my site back up and it is corrupt so I am screwed!
I know the Kuenna developers are stating that it should only be a few days but past experience is that they always overshoot the dates they suggest for a likely release significantly so if I can get a hold of a beta or even alpha that will run with Joomla 1.7 i will definately install it.
Support from Joomla for J1.6 ends in less than a month so we need a compatible version of Kuenna ASAP.
The topic has been locked.
14 years 9 months ago #101588
by xillibit
Replied by xillibit on topic Re: Is there an alpha or beta available for Kuenna 1.6.5
You can join the testers group to get a dev version to test it.
14 years 9 months ago #101590
by MfGLucker
Mark Twain
Replied by MfGLucker on topic Aw: Re: Is there an alpha or beta available for Kuenna 1.6.5
how can i join the tester group ?
Sammle erst die Fakten, dann kannst du sie verdrehen, wie es dir passt.
Mark Twain
14 years 9 months ago #101591
by MfGLucker
Mark Twain
joined, but have to wait for approval
Mark Twain
14 years 9 months ago - 14 years 9 months ago #101601
Replied by sozzled on topic Re: Is there an alpha or beta available for Kuenna 1.6.5
Answered by PM
People may apply to join the testers group by going here: www.kunena.org/people/groups/viewgroup/1...icial+Kunena+Testers
People should only apply to join the testers group if
Membership of all "official" Kunena groups is reviewed every month. People who have not contributed to the group for a period of time may have their membership cancelled.
- they are genuinely committed to helping the project by providing feedback; and
- they are experienced users of Joomla and Kunena.
Last edit: 14 years 9 months ago by sozzled.
