Question Having problems with the Ebay tag
15 years 4 months ago #101125 by Nemo10
The ebay item id given is invalid, no result has been sent
When you include the Item ID what is that exactly.. Just a number from the end of the url?
Not working for me.
Oh for a neat solution...
15 years 4 months ago #101491 by sozzled
No eBay APP ID and/or Cert ID defined in Kunena configurationThe ebay item id given is invalid, no result has been sentBasically, if you want to use the eBay tag to insert an ad, you use the item ID. For example, this BBcode:
[ebay]230579375207[/ebay]
produces the following ad:
But you can also extend the function to "search" for items on eBay, e.g.
[ebay]server[/ebay]
produces the following:
However, whether this works on your site, or not, depends on how you have configured the setting Forum Configuration » BBcode » BBcode settings » eBay widget language code. What value did you supply for that setting?
