Question Kunena_Menu Problems after activate Joomla SEF
15 years 4 months ago #100978 by mrangelo
Hello Folks,
My website works great until i decide to activate de SEF in Joomla (Site/Global Configuration...) Now the "Kunena Menu" bar (Index, Recent Topics, New Topic, etc) is displayed only in the first page of the forum but if i enter to any topic the Kunena_Menu is not displayed. I enter to the Kunena_Menu area and safe the menu and the problem continue, Im running ver 1.6.4. any help please.
Before activate the Joomla SEF:
After activate the Joomla SEF:
here's the configuration report:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
Joomla default template details : tiroalblanco8 | author: Angel A. Perez | version: 8.0 | creationdate: 2011-05-19
Kunena default template details : Cubo Pro K1.6 Template | author: www.TemplateKunena.com | version: 1.6.4 | creationdate: 2011-01-22
Third-party components: UddeIm 2.2
15 years 4 months ago #101005 by sozzled
15 years 4 months ago #101008 by mrangelo
Thanks, but i read and do the next steps and the problem continue:
How do I restore my Kunena menu?[2]
The Kunena menu is a set of tabs that appears across the top of the forum pages. In some cases, this menu does not appear for a variety of causes.
A simple remedy for the problem is to use the trash-burn-build technique:
1. Trash all existing menus and menu items that relate to your Kunena forum
2. Ensure that you do not have a folder named /forum on your site.
3. Empty the menu trash.
4. Use the Create Menu feature in the Kunena control panel to restore your Kunena menu.
5. Make sure that you publish a link in your menu that calls the Kunena forum. Use the Alias Menu type to define that link (see Customised menus for more information)
6. Ensure that you have published a menu module for the kunenamenu template position.
15 years 4 months ago #101009 by sozzled
Do you have this problem if you use the default Blue Eagle template?
Can you please post your updated K 1.6 configuration report?
I also recommend that you read our advice about using "legacy mode".
Thanks.
15 years 4 months ago #101010 by mrangelo
1- change to Blue Eagle Template : problem continue, i change to cubo pro again
2- Disable Legacy Mode ( i need it for other component) : problem continue, i enable the plugin again
3- here's is the report:
15 years 4 months ago #101017 by sozzled
You did not delete all menu items that link to your forum (your configuration report shows this to be the case). Please delete all menu items that relate to or link to your forum and then use the Create Menu feature.
If you have an old J! 1.0 extension - and we all know that J! 1.0 extensions are not supported and will eventually prevent you from upgrading your site to future supported versions of Joomla - then that's your choice and I guess you're stuck with having to use "legacy mode". Good luck with that.
Time to create page: 0.180 seconds
