Solved Moderators, Review Posts / Approval & Email Notification
15 years 4 months ago - 14 years 6 months ago #100152 by amackay
I require some help with Moderators and reviewing posts prior to posting. My configuration details are at the end of this post.
I have set several users as moderators on a forum category. I have also set the category so that Review Posts = Yes.
However the moderators do not receive email notification of new posts, and when they login pending approvals are not visible to them in the category list. Only Administrators are notified and can approve posts.
Thanks,
Annabel
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 512M | Max file upload: 12m
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
Last edit: 14 years 6 months ago by sozzled. Reason: Change subject and topic icon
15 years 4 months ago #100154 by sozzled
I am sorry but K 1.6.0 RC-1 is not a supported version. There were problems with review posts/approvals and email notifications with that version that have since been fixed. Please upgrade to K 1.6.4 (see K 1.6 Upgrade Guide .
The following user(s) said Thank You: amackay
15 years 4 months ago #100263 by amackay
I wonder also whether the RC version could be the cause of some other odd behaviour we've noticed and which is frustrating our users.
Depending on which category level you view, the actual last post is not listed. Rather the post prior is listed. Hence, users think there is nothing new when in fact there is
Thanks,
Annabel
15 years 4 months ago #100264 by sozzled
I realise this sounds like a recording but, I am sorry to say that K 1.6.0 RC-1 is not a supported version; it was never a supported version (no RC version is supported by anyone). There were problems with review posts/approvals and email notifications with that version that have since been fixed. Please upgrade to K 1.6.4 (see K 1.6 Upgrade Guide ). There were numerous issues with K 1.6.0 RC-1 that have been fixed (over 500 fixes have been made to Kunena since then) and that is the reason this old, pre-stable release is not supported.
15 years 4 months ago #100265 by amackay
That's okay. I figured I'd get the recorder message but wanted to be sure.
We will work with out website developer to get upgraded.
Thanks once more. The fast, clear and informative responses are excellent.
14 years 6 months ago #124606 by sozzled
*** Topic closed - no further response from user ***
Time to create page: 0.147 seconds
