Question Transferring posts and users
16 years 4 months ago - 16 years 4 months ago #52016 by pajo
No expert here so bear with me!
I have a .com site with a Kunena forum and a couple of thousand posts.
I recently set up a .info version of my site (non-public). I installed Joomla and basically created a whole new look for my site which I intend to transfer over to the .com version at the end of July.
The latest 1.5 version of Kunena is installed on both of them. Firstly, how difficult will it be to copy users and posts from one to the other?
I also contemplated installed the new 1.6 beta version on my .info site to test and possible make that upgrade with the new .com site design.
Would there be additional issues transferring users and posts from a 1.5 version to the 1.6 version?
Any help or advice greatly appreciated.
Last edit: 16 years 4 months ago by pajo.
16 years 4 months ago #52019 by Cerberus
do you have posts and users in both you want to merge of are you just wanting to move the LOOK (template) accross from ur .info site to your main site ??
16 years 4 months ago #52022 by pajo
The forum on my .info (test) site is empty.
16 years 4 months ago #52028 by Cerberus
Then yes it just the simple task of replicating any changes you made to ur TEST site over to the main site.
two ways of doing this ( always take a backup first ):
1. do each change one by one
or
2. copy all the file from your test site over the top of your main site and then main site will mirror test site ( rember to change the DB info to oringinal or posts and users wont be there)
FYI - i would advise not putting K1.6 on your live site just yet but your welcome to try it on your test site. :)
Key.
MAIN SITE = .com
TEST SITE = .info
16 years 4 months ago #52044 by sozzled
I'd like to offer my own observations about the question "Should I install K 1.6 now, on an empty website, and transfer my K 1.5 users and data across to it?"
I would not do things that way.
This is what I would do. You have a couple of weeks left until your target date, right?
I would copy the DB tables, jos_fb_* from your .com -> .info site and the following tables:
jos_core_acl_* (5 of them)
jos_users
jos_session
After you have experimented with K 1.6 on a test site, you can then upgrade from K 1.5 -> K 1.6
16 years 4 months ago #52049 by pajo
Thanks a lot guys, very much appreciate any help.
So could I transfer the DB tables to the .info site and have the users and posts on both forums?
Is there any sort of tutorial for this type of thing?
