Sticky K 1.7 How to setup CAPTCHA for registered users
14 years 9 months ago - 14 years 9 months ago #111961
by WeedRoy
K 1.7 How to setup CAPTCHA for registered users was created by WeedRoy
Hi, can any one tell me How to setup CAPTCHA for registered users ?
Tnx
Tnx
Last edit: 14 years 9 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
14 years 9 months ago #111979
by Matias
Replied by Matias on topic K 1.7 How to setup CAPTCHA for registered users
If you already know how to setup it for guests, you just need to enter a number into "CAPTCHA Challenge for Users". If the number is 3, all users who have less than 3 approved posts will get captcha challenge.
14 years 9 months ago #111992
by WeedRoy
Replied by WeedRoy on topic K 1.7 How to setup CAPTCHA for registered users
uhh..i dont understand
sry....
can u tell give me any tut or....idk....when any one register on my forum, and when hi write fist post i like be capcha available
p.s. sry for my bad english
tnx
sry....
tnx
14 years 9 months ago - 14 years 9 months ago #112004
Replied by sozzled on topic K 1.7 How to setup CAPTCHA for registered users
Thank you for your very good question, WeedRoy. Let me explain, clearly, what you need to do.
The instructions to use CAPTCHA for K 1.7.1 are in Using CAPTCHA spam protection in Kunena . In order to enable CAPTCHA so that, for the first message posted by a registered user, registered users must answer a CAPTCHA challenge. This is what you need to do:
Forum Configuration » Security » Security Settings » Allow Guests to Post/Write = Yes / No (does not matter)
Forum Configuration » Security » Security Settings » Registered Users Only = Yes / No (does not matter)
Forum Configuration » Security » CAPTCHA Configuration » CAPTCHA Challenge for Guests = Yes / No (does not matter)
Forum Configuration » Security » CAPTCHA Configuration » CAPTCHA Challenge for Users = 1
Forum Configuration » Security » CAPTCHA Configuration » reCAPTCHA Public Key = (obtained from www.google.com/recaptcha/admin/create )
Forum Configuration » Security » CAPTCHA Configuration » reCAPTCHA Private Key = (obtained from www.google.com/recaptcha/admin/create )
I hope that this explains how to enable CAPTCHA so that, for the first message posted by a registered user, registered users will have to pass the CAPTCHA challenge in order to post a message on your forum. If you want to increase this to, say, the first three messages posted by a registered user (the example given by Matias) then this is what you have to set:
Forum Configuration » Security » CAPTCHA Configuration » CAPTCHA Challenge for Users = 3
If you allow enforce CAPTCHA for guests then that's a different question and a different topic.
There's you tutorial!
14 years 9 months ago #112011
by WeedRoy
Because i was test this with other acc, it's work....
but i have last question....
because i am super administrator (administrator) on my forum, i cant see captcha?
tnx
tnx
14 years 9 months ago - 14 years 9 months ago #112012
If you read
you will see that the CAPTCHA challenge does not apply to administrators or moderators of your forum. This is because [it is reasonable to assume that] administrators and moderators appointed by you can be trusted to post whatever they want to without having to go through these "security" processes. Does this help you to understand?
Time to create page: 0.279 seconds
