Question Forum on Home page within article
15 years 2 months ago #99635
by ChrisL
Forum on Home page within article was created by ChrisL
Hi
I want to add a forum latest topic summary on my home page. Either in a module underneath the main article or as html at the bottom of the article itself. The format I require is as below:
Forum Topic Replies Views Last Post Posted By
General New Snooker League 16 636 2011-06-28 21:02 ChrisL
And so on....
First of all is this possible using an existing module (I couldnt find one) and secondly how would you suggest I achieve this using coding if required?
And so on....
15 years 2 months ago #99636
Replied by sozzled on topic Re: Forum on Home page within article
Does the "summary" display, that appears on the home page of this website -
www.kunena.org
- appeal to you?
15 years 2 months ago #99730
by ChrisL
Replied by ChrisL on topic Re: Forum on Home page within article
I have looked at that but it will only appear in a module position to the left or right column or footer etc.
I want this to appear in the centre position underneath the featured article.
I also want it to be formatted as above including posts and views. Has anyone included a forum topic summary similar to this on their home page?
15 years 2 months ago - 15 years 2 months ago #99731
If I understand your question correctly, you are happy with the information provided by the Kunena Latest module but you would like to publish this module in a different place on your website. Is that correct?
Last edit: 15 years 2 months ago by sozzled.
15 years 2 months ago #99732
by ChrisL
Hi not entirely.
This is the site:
www.cmlwebdesign.com/new/aberdeensnooker/
I want the latest topic list (say 20 items) to appear in the white space beneath the featured article. I would like it in the format of:
And so on....
Is this possible do you think? I think the replies an views columns may not be in the Kunena Latest module.
This is the site:
And so on....
15 years 2 months ago - 15 years 2 months ago #99733
Thanks for clarifying the issue further. If, again, I may restate the topic in terms that help me understand your question better, are you looking for a feature that allows your users to comment upon and engage in discussion about Joomla articles that you write.
For example, would the feature that you see on the home page of this site (scroll to the bottom of the page) and on other articles written here (see the Blog ) - is that the kind of thing that you are looking for?
