Question Everyone can read unpublished category and its article
15 years 5 months ago #97754 by marco168
Everyone can find and read the unpublished categories from search engine, and can also find the articles under these categories.
Is there any methods to hide them from normal users and hide from search engine for better SEO?
Any comments/ideas are appreciated.
Thanks a lot=]
15 years 5 months ago - 15 years 5 months ago #97817 by sozzled
Yes, it's possible for people to search for topics/discussions in categories that are unpublished and maybe that's something that needs to be looked into.
Using an example from this website, I searched for "Hey, i recently did a fresh website install thus having latest joomla" and, you are right, I found this text in an old, unpublished category on the site.
The specific category in question is ARCHIVE - Support which is not published.
Furthermore, if I use Google to search for the same string, I get a similar result.
And so your observation is correct. The question is, what needs to be done about this to hide that information from the search engines? That's something I will need to discuss with the project team.
Good question. I don't have an answer at the moment.
One possibility is to quarantine access to the category in some way (e.g. require that you must be logged-in to access the category) and this will probably stop internet search engines detecting these things.
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #97823 by marco168
I also believe that quarantine access can solve the problem.
A error message "Category has been unpublished" should be given.
Like the current version, if a normal users in this forum want to post new thread in announcement catagory, a error message "Category has been locked." will be given.
Try: www.kunena.org/forum/newtopic/76-officia...nd-news-about-kunena
No sure if it could hide from search engine, but at least normal users cannot access it.
One more issue, it's better to hide article in unpublished category in module "mod_kunenalatest" and "mod_kunenastats".
Thanks for your opinion=]
15 years 5 months ago #97824 by sozzled
See Sections, Categories, sub-Categories (Part 2) - advanced setup for special groups . This will show you how to restrict access to categories and that might be the way to deal with the issue until a better solution can be developed.
The following user(s) said Thank You: marco168
15 years 5 months ago #97826 by marco168
A quick setting can be used.
We can set "Public Access Level:" in Category Manager to "none". And no normal users can access these categories and article.
Hope a proper solution of this issue can be found before next update.
Thanks sozzled for the opinion and help=]
15 years 5 months ago #97887 by Matias
If parent category is unpublished, child categories still keep on working (K1.6). So there's no inheritance.
If unpublished category is showing up, there must be bug in the logic. If there is, it's already fixed in K2.0.
