Question How to streamline the K1.6.4. Index view?
15 years 6 months ago #96113 by csolar
Is there a simple way to streamline the forum index view? I'd like to turn off things like:
- The "Who is online" section
- The "Forum Statistics" section
- The user welcome/registration/login section
I'm sure these are useful on some sites, but for me at least they add a lot of clutter to the page...the forums themselves are buried under all this extra stuff.
I see that these sections can be minimized, but I don't see how I can have them default to being minimized. Better still would be to turn these things off completely.
Is there a way to do this without hacking into the code?
Thanks, Chris.
Config settings:
Joomla default template details : siteground-j15-86 | author: SiteGround | version: 1.0.0 | creationdate: 08/2009
15 years 6 months ago #96130 by sozzled
Yes, you can turn off "Who is online" section: Forum Configuration » Plug-ins » Statistics Plug-in Settings » Show Who is Online = No
Yes, you can turn off the "Forum Statistics" section: Forum Configuration » Plug-ins » Statistics Plug-in Settings » Show Statistics = No
Yes, you can turn off the user welcome/registration/login section: Forum Configuration » Integration » Integration Options » Login and Registration = None
