Question [Merged topic] Displaying images side by side in Kunena
Let's see how this looks:
I did this with the BBcode table markup:
[*table]
[*tr]
[*td][*img] docs.kunena.org/images/6/6d/Kunena.logo.png [*/img][*/td]
[*/tr]
[*/table]
Remove all the asterisks from the above and you will see it rendered on your site just like it shows here at this site.
two Month ago and no Fix????
really bad
Gruß Mark
Pickup-Wohnkabinen-Forum Kunena 4.0.7
Chevy-Forum Kunena 3.0.8
Gruß Mark
Over the past 2½ years that Kunena has existed, it seems that these "side-by-side" image display issues surface, disappear and then resurface again. The problem wasn't there in K 1.6.3 but now it's back again. That's unfortunate.
In my opinion, I agree with you that images should be rendered side-by-side, and that behaviour should not change from one version of Kunena to the next. We agree that this issue is one that needs to be addressed and it should be addressed in a simpler manner than by using a "table" construct. Having said that, I do not know how to resolve this issue for K 1.6.4 except than by working around the issue as I have demonstrated. If this approach is unsustainable in your environment then you have my understanding but I don't have a technical solution for you.
This is something that needs further investigation and resolution for a future release of Kunena. In the meantime, perhaps someone else in the community has found a technical solution and they might like to share their solution with the rest of the community.
