Question When Deleting a Post with attachment, attachment still remains?
15 years 6 months ago #94725 by xillibit
To check that the images are right deleted you need to use the delete permanently function or in trash manager by using delete permanently function too
15 years 2 months ago #107002 by rado
hello there,
in the file
(JOOMLA ROOT)/components/com_kunena/lib/kunena.moderation.class.php
I had to change
// Check that message to be moved actually exists
if ( !is_object($currentMessage) ) {
with
if ( !is_object($currentMessage) && $mode!=KN_DEL_ATTACH) {
because messages are removed before of attachments!
this works for me.
15 years 2 months ago #107740 by xillibit
I will take a look at this later
15 years 2 months ago #107786 by xillibit
rado wrote: hello there,
in the file
I had to change
with
this works for me.
This doesn't work for me, my fix is different
Line 328 add $this->deleteAttachments($MessageID);
The following user(s) said Thank You: Matias
