Question Call to undefined method CKunenaTools::editTimeCheck()
15 years 5 months ago - 15 years 5 months ago #93256 by Quov
Normal User trys to start a new Thread, getting this Error:
Fatal error: Call to undefined method CKunenaTools::editTimeCheck() in C:\Ausbildung\Xampp\xampp\htdocs\joomla\components\com_kunena\funcs\view.php on line 269
Thread is posted completlt though, here is the code of the mentioned line:
else if ($this->config->useredit && $this->my->id && $this->my->id == $this->profile->userid) { //Now, if the viewer==author and the viewer is allowed to edit his/her own post then offer an 'edit' link if ($message->hold != 2 && CKunenaTools::editTimeCheck($message->modified_time, $message->time)) { $this->message_edit = CKunenaLink::GetTopicPostReplyLink ( 'edit', $this->catid, $this->id, CKunenaTools::showButton ( 'edit', JText::_('COM_KUNENA_BUTTON_EDIT') ), 'nofollow', 'kicon-button kbuttonmod btn-left', JText::_('COM_KUNENA_BUTTON_EDIT_LONG') ); if ( $this->config->userdeletetmessage == '1' ) { if ($this->replynum == $this->replycnt) $this->message_delete = CKunenaLink::GetTopicPostLink ( 'delete', $this->catid, $this->id, CKunenaTools::showButton ( 'delete', JText::_('COM_KUNENA_BUTTON_DELETE') ), 'nofollow', 'kicon-button kbuttonmod btn-left', JText::_('COM_KUNENA_BUTTON_DELETE_LONG') ); } else if ( $this->config->userdeletetmessage == '2' ) { $this->message_delete = CKunenaLink::GetTopicPostLink ( 'delete', $this->catid, $this->id, CKunenaTools::showButton ( 'delete', JText::_('COM_KUNENA_BUTTON_DELETE') ), 'nofollow', 'kicon-button kbuttonmod btn-left', JText::_('COM_KUNENA_BUTTON_DELETE_LONG') ); } } }
Any Ideas?
Edit:
Admins and Mods do not get any Errors,Thread will be posted.
Kunena V 1.6.3
Last edit: 15 years 5 months ago by Quov.
15 years 5 months ago #93275 by xillibit
Can-you put here please your Kunena configuration report ?
15 years 5 months ago #93280 by Matias
It looks like Joomla couldn't update all the files (\components\com_kunena\class.kunena.php). Please check that the function exists in that file and that the file is the latest version.
If not, easiest way to fix this is to remove the file and run the installer again to add missing files.
15 years 5 months ago #93359 by Quov
Don't ask me why but - this section of the code has been commented out.
I really do not know why - no one else is able to view the code and last changes has been made with installation.
Well, thanks for your advice, but I still do not get, why only normal Members got this Error.
Thanks for advance.
