Question Userlist and userlist search
15 years 7 months ago #92827 by 810
Do you want this?
15 years 7 months ago #92828 by menew
Yes .thanks for the efforts.. can you tell the paths in configuring it? i mean hows
15 years 7 months ago #92829 by sozzled
menew wrote: Yes .thanks for the efforts.. can you tell the paths in configuring it? i mean hows
I don't understand what you mean. What "paths" are you trying to configure? What would you like to "configure" with the user list? Have you looked at the Kunena Forum Configuation » Plugin options?
15 years 7 months ago #92830 by menew
Yes sir I have looked into it.. and it showing fine..
But i can't find a way to display the userlist in my forum..
incase if you you haven't read the above post.. can i list the userlist in a menu..
thank you
15 years 7 months ago #92831 by 810
Backend-menu-kunenamenu-add-external url: index.php?option=com_kunena&func=userlist&Itemid=75 (75 = is your itemid)
regards 810
15 years 7 months ago #92832 by menew
snapshot of the plugin..
I can't see any options to enable it and have it running in the forum
