Question How do I set forum to notify me...
15 years 7 months ago #91177 by dtarver
Hi
I am using Powered by Kunena forum on my website. How do I configure it to notify me when ever anyone makes a post?
15 years 7 months ago #91185 by sozzled
G'day, dtarver, and welcome to Kunena.
It's difficult to answer this question because the specific instructions differ depending on which version of Kunena you are using. Further, the General Talk about Kunena category - in which you posted your question - is not really the place to ask questions about how to use Kunena. We have dedicated categories (depending on which version of Kunena you are using) for asking those things.
As a general rule, though, you can receive e-mail notification of new messages posted to your forum (if that's what you want to do) either as the administrator or as a forum moderator. There are configuration settings for doing this. I can show you where if you tell us what version of Kunena you are using.
15 years 7 months ago #91188 by sozzled
I read in another topic that you created, you are using K 1.6.3 on J! 1.5.22.
I have moved your topic to a more appropriate category.
You should look at the following two settings:
Forum Configuration » Security » Security Settings » E-mail Moderators = Yes
Forum Configuration » Security » Security Settings » E-mail Administrators = Yes
I hope this helps.
