Question Catagory / Post links problem
15 years 8 months ago - 15 years 8 months ago #89803 by MrBlonde
I've been trying to get to the bottom of an ongoing problem with my forum. The problem being that it looses it's links to the categories and posts every once in a while. Through arbitrary trial and error I seem to get it back up and working somehow, BUT NOT THIS TIME!!!
The site is www.swedgeville.org .It's running Joomla 1.5.22 and Kunena 1.6.3
I don't know whether it has any baring on the issue, but I never did get my head around kunenamenu.
I suspect it's an easy one to sort, but not for me this occasion and our forums are down as a consequence. So if an admin here would like back-end access to take a look around then please just shout.
Anyway, here's the report. People are chomping at the bit so any help is very much appreciated. Many thanks!
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : rt_afterburner_j15 | author: RocketTheme | version: 1.5.0 | creationdate: 08/07/09
Kunena default template details : New V2 | author: 810 | version: 1.6.0 | creationdate: 2010-10-23
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Last edit: 15 years 8 months ago by MrBlonde.
15 years 8 months ago #89850 by sozzled
You have a problem with the way you have set up your Joomla menu; I can see it in your K 1.6 configuration report. I recommend that you trash and burn all your existing forum menu items, links, module as use the Create Menu facility to establish a proper basis from which you can go forward.
15 years 8 months ago #89894 by MrBlonde
The moment I tried to recreate the main menu the following came up :
"Warning: require_once(/home/swedgevi/public_html/modules/mod_mainmenu/helper.php) [function.require-once]: failed to open stream: No such file or directory in /home/swedgevi/public_html/modules/mod_mainmenu/mod_mainmenu.php on line 18
Fatal error: require_once() [function.require]: Failed opening required '/home/swedgevi/public_html/modules/mod_mainmenu/helper.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/swedgevi/public_html/modules/mod_mainmenu/mod_mainmenu.php on line 18"
Screwed up mainmenu module? Any clues on the next step?
15 years 8 months ago #89895 by sozzled
