14 years 8 months ago - 14 years 8 months ago #120473 by xtzetzias
Hi all here in Kunena! Thank you for the nice job you do.
I face the problem of the subject: i can see smiles, but not the icons above them.
I searched through the forum and was not able to find a solution. Most of the stuff refer to joomla 1.5.x
I use Joomla 2.5, Kunena 1.7.1 and my template is Allrounder. Problem occured in Firefox and Chromium.
The problem appeared when added in my template's header the following code:
<link rel="stylesheet" type="text/css"
href=" latex.codecogs.com/css/equation-embed.css " />
<!--[if lte IE 7]>
<link rel="stylesheet" href=" latex.codecogs.com/css/ie6.css " type="text/css"/>
<![endif]-->
<script type="text/javascript"
src=" latex.codecogs.com/js/eq_config.js " ></script>
src=" latex.codecogs.com/js/eq_editor-lite-11.js " ></script>
It was needed for a latex editor to work. when i removed the code, everything was ok again.
How can i kepp both the code and the icons?
Thanks in advance
Last edit: 14 years 8 months ago by xtzetzias.
14 years 8 months ago #120481 by sozzled
G'day, xtzetzias, and welcome to Kunena.
You sort of answered your own question. What you found was that the LaTex code editor uses Javascript that conflicts with Joomla. You need to talk with the author of the LaTex code editor, point them to this topic, and ask them what they're going to do about it?
14 years 8 months ago #120579 by allen012087
can anyone tell me what could be the reason the attachment button is not responding when i click on it? is it because some jquery conflicts or some other? thank you
14 years 8 months ago #120581 by sozzled
allen012087 wrote: can anyone tell me what could be the reason the attachment button is not responding when i click on it? is it because some jquery conflicts or some other? thank you
Very likely, yes. A conflict with another Javascript library could be the reason.
See msg #1 of this topic for more information.
14 years 8 months ago #120789 by lurd.sammie
Hello there,
I have Kunena 1.7 installed on Joomla 2.5. I wanted to upload avatar and update signature but once I got to the profile page I noticed there are no links to allow editing the profile.
This the same with all the test users created.
Pls see below a generated report.
Hope someone can help.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : rt_modulus | author: RocketTheme, LLC | version: 1.6.5 | creationdate: February 16, 2012
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.2
Modules: Kunena Latest 1.7.2
14 years 8 months ago #120791 by gimenezadrian
Please uncheck Title Spans from the template manager
Time to create page: 0.188 seconds
