Question Artio Url Problem... forum urls...
15 years 9 months ago #84545 by LeroanZ
hi friends, i installed Artio Sef and i installed kunena extension, although i changed everything i can't showed without forum id...
I don't want to showed Forum id in url...
for example; www.website.com/forum/yonetici-forumu/awdasa.html #116
i don't want to this #116 id... just url ... how can i do it could you explain step by step ?
Thanks a lot...
15 years 9 months ago #84691 by Matias
Our setting works only if you are using Joomla SEF. Artio may or may not have the same feature -- I don't know. You should ask it from their support.
There are many issues that can potentially raise if you're not using ids. One is that by renaming category you will loose your page rank because of the pages cannot be found anymore.
