Question Right configuration for setting a forum to be ONLY moderated for posts by unregistered users
15 years 9 months ago - 15 years 9 months ago #84083 by mikeazores
Hi there!
I tried to search in this forum for the right configuration of a forum to be moderated and manually approved posts when those posts are made by unregistered users.
If a registered user posts in that forum, his post should be automatically approved.
Thanks for any tip.
Regards.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 32M | Max file upload: 5M
Joomla default template details : | author: | version: | creationdate: October 14, 2010
Kunena default template details : Saludterapia | author: Saludterapia | version: 1.0.0 | creationdate: 2010-11-08
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Installed (Version : 1.5.11) | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.0.4) | UddeIm: Disabled or not installed
Mike - Joomla developer for Saludterapia!
Last edit: 15 years 9 months ago by mikeazores.
15 years 9 months ago #84140 by xillibit
approved posts function works for every users except moderators, for the moment it doesn't make the difference between registred and guest users
15 years 9 months ago #84154 by mikeazores
Thanks xillibit.
I hope Kunena gets this functionality..
By the way, congrats for tdeveloping the best forum for Joomla.
Cheers
15 years 9 months ago #84937 by scuriza
xillibit wrote: Hi,
I'm looking for this issue on the Kunena, but I don't find where is the configuration for this.
I need to ban the user from the forum first? Or I need to check a specific forum or topic to get all their messages moderated?
What I need to do? Help please.
Thanks.
15 years 9 months ago #84940 by mikeazores
scuriza wrote:
xillibit wrote: Hi,
Thanks.
You can do it from Category Manager. When editing a category in Settings tab you must set "Review Posts" to YES
